AN803 run in Quartus 21.3
- 4 years ago
Hi David,
Apologize for the late response as I had been busy on other stuff.
May I know if there is any update/progress you can share on the platform system simulation and the example design
Hi David,
Thank you for the brief and attachment and one concern here:
"I loaded on the dev board and it working. I have been working for several days to create an simulation, but still not successful"
- You mean the hardware is working correctly including the cpu data and instruction bus but not in simulation, am I right?
If you can provide me some suggestion on AN803
- Let me check internally and let you know any findings.
Hi SyafieqS
Yes, you are right, I can download the AN803 sof to the board, and seems it is working. but the goal is not to make it working, is to use it as an example to learn how to use it. for final design, I need do some system level simulation, I hope I can build a JESD204B simulation environment, because it will be hard and time consuming to troubleshoot it directly on the board, even with signal tap tools.
I almost completed most of the functional module, I can see Nios2 running, spi interface working. so, I am ready to work on the most difficult part.
The FPGA design and tools are becoming so complicate.
Thank you very much.
David
