AN803 run in Quartus 21.3
- 4 years ago
Hi David,
Apologize for the late response as I had been busy on other stuff.
May I know if there is any update/progress you can share on the platform system simulation and the example design
David,
That is true, you only need to purchase a full production license for licensed Intel FPGA IP cores
after completing hardware testing and you are ready to use the IP in production. The
rest of the time, you can use the Intel FPGA IP Evaluation Mode feature to evaluate IP
cores. During Intel FPGA IP Evaluation Mode, the Intel Quartus Prime Compiler only generates a time-limited device programming file (<project name>_time_limited.sof) that expires at the time
limit. You can refer to Intel® FPGA Software Installation and Licensing for more detail.
- dsun014 years ago
Contributor
thank you for your reply.
