AN803 run in Quartus 21.3
- 4 years ago
Hi David,
Apologize for the late response as I had been busy on other stuff.
May I know if there is any update/progress you can share on the platform system simulation and the example design
Hi David,
Jesd204 IP need license to be simulated otherwise you wont be able to pass the compilation which produce netlist vo/vho needed by the simulator.
- dsun014 years ago
Contributor
I thought the license only control the generation of the compile output, didn't expect the license will block the simulation. then there will be a chick and egg problem, how do the customer know the IP is working before purchasing the license, as I know the license is very expensive.
out team did purchase one copy of the Jesd204B license, in this simulation case, how to disable the simulation protection. could you please give me the link to the user manual or data sheet that talking about the protection and active the license to do the simulation.
Thank you,
David
