15 years ago
An Interna Error while using quartus II 9.0
Interna Error: Sub-system:BPM,File:/quartus/db/bpm/bpm_boundary_port_manager_impl.cpp,Line:110
m_netlist
Stack Trace:
0x619F: BPM_BOUNDARY_PORT_MANAGER_IMPL::BPM_BOUNDARY_PORT_MANAGER_IMPL+0x9F(db_bpm)
End-trace
Quartus II Version 9.0 Build 132 02/25/2009 SJ Full Version
I've met this problem for some days, and don't know how to solve it. If you know why, will you give me the resolusion or some advice? Many thanks!
    9.0 is quite old! Is it possible to move to a newer version of Quartus?
    Anyways, the most common cause of this IE in 9.0 that I can find is related to parallel synthesis. A workaround is to check your QSF to see if this feature has been enabled and if so to disable it by adding:
    set_global_assignment -name PARALLEL_SYNTHESIS off
    --- Quote Start ---
    I've solved this problem by your help, thank you very much!
    --- Quote End ---
    how to
    do that
    i am trying to complie the example in university program and i am getting
    the following error
    Internal Error: Sub-system: BPM, File: /quartus/db/bpm/bpm_boundary_port_manager_impl.cpp, Line: 110
    m_netlist
    Stack Trace:
    0x619F : BPM_BOUNDARY_PORT_MANAGER_IMPL::BPM_BOUNDARY_PORT_MANAGER_IMPL + 0x9F (db_bpm)
    End-trace
    please help me
    try deleting the DB directory?
    have you tried a newer version of quartus?
    ya i tried but its not compiling it is givimg the same error
    actualy i am trying to compile the example in the univesity program
    can u tell how i get the new version ???
