--- Quote Start ---
There will be another following post to show some part of my code of one of the state machine.
--- Quote End ---
1) First Trial: using verilog function call
pIOWRITE_IN_PRGS1_BAR0:
begin
lt_rdyn_bar0 <=0;
dataReg <=receiveDataFromPCI(benReg,l_dato);
end
/* function name: receiveDataFromPCI */
/* parameter : [3:0] benReg-> PCI Byte Enable Signal */
/* [31:0] data -> Data to be return to PCI bus */
/* return value : 32 bits data arranged corresponding to BEN signal */
function [31:0] receiveDataFromPCI;
input [3:0] benReg;
input [31:0] data;
begin
if(benReg == 4'h0) //Arrangment of data in data byte path corresponding to BEN for 32bits family I/O card
receiveDataFromPCI[31:0] =data[31:0];
else if(benReg == 4'h1)
receiveDataFromPCI[31:0] ={8'h00,6'h00,data[25:8]}; //Arrangment of data in data byte path corresponding to BEN for 18bits family I/O card
else if(benReg == 4'h2)
receiveDataFromPCI[31:0] ={8'h00,6'h00,data[25:16],data[7:0]};
else if(benReg == 4'h4)
receiveDataFromPCI[31:0] ={8'h00,6'h00,data[25:24],data[15:0]};
else if(benReg == 4'h8)
receiveDataFromPCI[31:0] ={8'h00,6'h00,data[17:0]};
else if(benReg == 4'h3)
receiveDataFromPCI[31:0] ={16'h0000,data[31:16]}; //Arrangment of data in data byte path corresponding to BEN for 16bits family I/O card
else if(benReg == 4'h5)
receiveDataFromPCI[31:0] ={16'h0000,data[31:24],data[15:8]};
else if(benReg == 4'h6)
receiveDataFromPCI[31:0] ={16'h0000,data[31:24],data[7:0]};
else if(benReg == 4'h9)
receiveDataFromPCI[31:0] ={16'h0000,data[23:8]};
else if(benReg == 4'hA)
receiveDataFromPCI[31:0] ={16'h0000,data[23:16],data[7:0]};
else if(benReg == 4'hC)
receiveDataFromPCI[31:0] ={16'h0000,data[15:0]};
else if(benReg == 4'h7) //Arrangment of data in data byte path corresponding to BEN for 8bits family I/O card
receiveDataFromPCI[31:0] ={24'h00_0000,data[31:24]};
else if(benReg == 4'hB )
receiveDataFromPCI[31:0] ={24'h00_0000,data[23:16]};
else if(benReg == 4'hD)
receiveDataFromPCI[31:0] ={24'h00_0000,data[15:8]};
else if(benReg == 4'hE)
receiveDataFromPCI[31:0] ={24'h00_0000,data[7:0]};
else
receiveDataFromPCI[31:0] =32'h0000_0000;[/INDENT]
end
endfunction
2) Second Trial: without using verilog function call
begin
lt_rdyn_bar0 <=0;
//dataReg <=receiveDataFromPCI(benReg,l_dato);
dataReg[PCIDATAWIDTH-1:0] <=l_dato[PCIDATAWIDTH-1:0];
dataReg[PCIDATAWIDTH-1:0] <={8'h00,6'h00,l_dato[25:8]};//Arrangment of data in data byte path corresponding to BEN for 18bits family I/O card
dataReg[PCIDATAWIDTH-1:0] <={8'h00,6'h00,l_dato[25:16],l_dato[7:0]};
dataReg[PCIDATAWIDTH-1:0] <={8'h00,6'h00,l_dato[25:24],l_dato[15:0]};
dataReg[PCIDATAWIDTH-1:0] <={8'h00,6'h00,l_dato[17:0]};
dataReg[PCIDATAWIDTH-1:0] <={16'h0000,l_dato[31:16]}; //Arrangment of data in data byte path corresponding to BEN for 16bits family I/O card
dataReg[PCIDATAWIDTH-1:0] <={16'h0000,l_dato[31:24],l_dato[15:8]};
dataReg[PCIDATAWIDTH-1:0] <={16'h0000,l_dato[31:24],l_dato[7:0]};
dataReg[PCIDATAWIDTH-1:0] <={16'h0000,l_dato[23:8]};
dataReg[PCIDATAWIDTH-1:0] <={16'h0000,l_dato[23:16],l_dato[7:0]};
dataReg[PCIDATAWIDTH-1:0] <={16'h0000,l_dato[15:0]};
dataReg[PCIDATAWIDTH-1:0] <={24'h00_0000,l_dato[31:24]};
dataReg[PCIDATAWIDTH-1:0] <={24'h00_0000,l_dato[23:16]};
dataReg[PCIDATAWIDTH-1:0] <={24'h00_0000,l_dato[15:8]};
dataReg[PCIDATAWIDTH-1:0] <={24'h00_0000,l_dato[7:0]};
else
dataReg[PCIDATAWIDTH-1:0] <=32'h0000_0000;[/INDENT]
end
