ALTMULT-ACCUM (Multiplier-accumulate) Alternative
- 5 years ago
Hi Shainy,
You're using the wrong IP. You should be using ALTERA_MULT_ADD, you can refer to this document: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_lpm_alt_mfug.pdf#page=36
Prior to Quartus II v14.0, these IP cores were called Megafunctions and used MegaWizard Plug-In to be generated into the design. Starting from Quartus II v14.0, they're referred to as IP, and you are required to use IP catalog to generate them. Although it's been a long time since Quartus v14.0, for Cyclone V devices, the MegaWizard Plug-In will be prompted to select the parameters after you have selected the Arithmatic IP core on IP catalog.
Nurina
Hi Nurina,
Thank you so much for the guidance! I'll refer to the document given above. Thanks again!
Shainy
Hi Shainy,
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
