12 years agoWhen you say manual, do you mean manually picking a setting, or dynamic, whereby you can load in different values in system? If it's the former, I believe you can do it with I/O assignments in the Assignment Editor. I'm not sure about the latter.
(For the error message, I'm guessing the block is called DPA, even if it's not doing DPA, but the real issue is the legality check for what can be connected to it. I would be surprised if there is an easy way around it.)
