18 years ago
altlvds Transmitter in MegaWizard
Hi All,
I am currently using 'altlvds' for transmitting data(See Below).
For tx_in I have assigned a 10 bit data and for tx_inclock I assigned 100Mhz CoreClock.
I am not getting any data from the output ports.
Could anyone please help me in regard?
Thanks in advance
Sandeep
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera_mf;
USE altera_mf.all;
ENTITY LvdsTx IS
PORT
tx_in : IN STD_LOGIC_VECTOR (9 DOWNTO 0);
tx_inclock : IN STD_LOGIC := '0';
tx_coreclock : OUT STD_LOGIC ;
tx_out : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);
tx_outclock : OUT STD_LOGIC
END LvdsTx;
ARCHITECTURE SYN OF lvdstx IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (0 DOWNTO 0);
SIGNAL sub_wire1 : STD_LOGIC ;
SIGNAL sub_wire2 : STD_LOGIC ;
COMPONENT altlvds_tx
GENERIC (
common_rx_tx_pll : STRING;
deserialization_factor : NATURAL;
implement_in_les : STRING;
inclock_data_alignment : STRING;
inclock_period : NATURAL;
inclock_phase_shift : NATURAL;
intended_device_family : STRING;
lpm_hint : STRING;
lpm_type : STRING;
number_of_channels : NATURAL;
outclock_alignment : STRING;
outclock_divide_by : NATURAL;
outclock_phase_shift : NATURAL;
outclock_resource : STRING;
output_data_rate : NATURAL;
registered_input : STRING
PORT (
tx_outclock : OUT STD_LOGIC ;
END COMPONENT;
BEGIN
tx_out <= sub_wire0(0 DOWNTO 0);
tx_outclock <= sub_wire1;
tx_coreclock <= sub_wire2;
altlvds_tx_component : altlvds_tx
GENERIC MAP (
common_rx_tx_pll => "ON",
deserialization_factor => 10,
implement_in_les => "OFF",
inclock_data_alignment => "UNUSED",
inclock_period => 10000,
inclock_phase_shift => 0,
intended_device_family => "Stratix",
lpm_hint => "CBX_MODULE_PREFIX=LvdsTx",
lpm_type => "altlvds_tx",
number_of_channels => 1,
outclock_alignment => "UNUSED",
outclock_divide_by => 10,
outclock_phase_shift => 0,
outclock_resource => "AUTO",
output_data_rate => 1000,
registered_input => "TX_CORECLK"
PORT MAP (
tx_in => tx_in,
tx_inclock => tx_inclock,
tx_out => sub_wire0,
tx_outclock => sub_wire1,
tx_coreclock => sub_wire2
END SYN;
    From the parameter list, I read Stratix device and data rate of 1000 MHz. I thought maximum datarate for Stratix LVDS transmitter would be 840 MHz?
    I am glad to receive a quick response from you.
    Ya you are right its 840MHz. But in my design I have used 'output data rate' is 1000Mbps and a deserilization factor of 10 hence the input clock frequency is 100Mhz and out clock frequency is 1Ghz (which is not possibe as it is limitted to a maximum of 717 Mhz). Therefore I have used a outclock divide factor of 10.
    The issue is resolved ;). The problem was when I tried to simulate my project in Modelsim the Stratix PLL was not getting locked with the incoming clock. A friend of mine suggested me to change time to 1ps before simulation. Now, the Stratix PLL is locked to the incoming clock and it is working fine.
    Thanku very much
    reg
    Sandeep
    Yes, I also took some time before I realized how to operate PLLs in ModelSim. By the way, you should always mention if it's a simulation or hardware problem. The comfortable thing in ModelSim is, you can inspect any signal, e. g. PLL locked signal without recompiling the design. So it's basically easy to identify a non-operating PLL.
    Ohh.. I am sorry for not mentioning it. Ya! ur right I actually dint notice the warning message.
    Danke,
    Sandeep
