14 years agoHi bourazza,
--- Quote Start --- Hello, I am so sorry, I am just new in this forum, and my english is not so good that's why I was not so clear. --- Quote End --- Your English is just fine, as I commented, you didn't tell us what you had tried already. --- Quote Start --- I am using quartus 10.1 and stratix iv GX I am working on a project to realize a DVI interface using serdes. I did all my blocs using sopc builder and megawizard. on my output I must have 8 chennels of outputs (chR+, chR-, chB+, chB-, chG+, chG-) of one bit each one. I used the ALTLVDS for the serdes then i had 4 outputs, and to have the (-) and the (+) for each one I used ALTIOBUF. When I assigned the pins name in the assignement editor I don't know which caracteristic I must have to this pins. hope I was clear and thank you a lot for your replay. :) --- Quote End --- You haven't stated which physical pins on the device you have tried. You didn't state exactly which Stratix IV GX device part number you are using. The answer to your question can be found in the pin connections guideline spreadsheet found on the Altera web site; http://www.altera.com/literature/dp/stratix4/pcg-01005.pdf and in the pinout for your specific part number: http://www.altera.com/literature/lit-dp.jsp?category=stx%204&showspreadsheet=y You need to check which pins are capable of operating with LVDS logic levels. Is this a custom board, or an Altera kit? If it is an Altera kit with an HSMC connector, then pins on that connector have been defined LVDS operation eg., see the Stratix IV GX development kit. Cheers, Dave
