10 years agoaltera v gt board
i want to program directly the altera v gt board. i generate a 'sof' file and burn it into the fpga1 but not getting the output. is there is any switch setting to direct program the device. i want to...
10 years agoThe HSMA_RX_P/N* pairs connect to Arria V transceivers - high performance compared to other I/O. The HSMA_RX_D_P/N* pairs connect to more 'standard' I/O pins.
--- Quote Start --- is any limitation in HSMA_RX_P/N* --- Quote End --- Yes, you will need to connect the HSMA_RX_P/N* pairs into transceivers. The minimum operating frequency of these is 600Mbps. You will also need to find a way to align the recovered transceiver data with the data coming in through the standard I/O pins. Cheers, Alex
