10 years agoaltera v gt board
i want to program directly the altera v gt board. i generate a 'sof' file and burn it into the fpga1 but not getting the output. is there is any switch setting to direct program the device. i want to...
10 years agoYou can't use the HSMA_TX_D_P/N* pins.
However, across the HSMC_A port (referring to the schematic) you have the HSMA_RX_P/N* pairs and the HSMA_RX_D_P/N* pairs, all of which can be used as input pairs. So, you have 25 pairs. You also still have the HSMA_CLK_P/N 1 & 2 which could be use as additional inputs or clock inputs. Cheers, Alex
