10 years agoaltera v gt board
i want to program directly the altera v gt board. i generate a 'sof' file and burn it into the fpga1 but not getting the output. is there is any switch setting to direct program the device. i want to...
10 years agoUsing the .sof to program the FPGA is fine. However, if you power cycle the board you will need to program the FPGA again.
If you're 'not getting the output', while the board is powered and programmed, then it's probably pointing to a problem with your code. Cheers, Alex
