Samet
5 years agoAltera Usb Blaster
Hello
I cannot communicate with USB Blaster via Quartus II Software.
I am trying to read Altera EMP7032SLC44-10 IC software. I need to get the software from inside the IC.
I am connection to Al...
YuanLi_S_Intel
5 years agoHi,
Thank for the clarification. It seems like power supply is the issue for this.
This is what I want to do; I want to read the software of the IC that I removed from the device.
May i know which software are you referring to? Are you referring to image file in FPGA? Please clarify.
but IC jtag ports are disabled. Is there a method to enable jtag ports?
Which IC JTAG Port are disabled? I dont get it. Now your FPGA is able to be detected by USB Blaster after you have provided sufficient power voltage. You should be able to program image file such as SOF, JIC into the device already.
- Samet5 years ago
Hello, ALTERA EPM7032SLC44-10 IC disabled. I am running this IC with byteblaster II. If we can enable communication channels, I want to get the (pof) file or image file in it. How can we enable the EPM7032SLC44-10 IC disabled and read the image file in it?
