Samet
5 years agoAltera Usb Blaster
Hello
I cannot communicate with USB Blaster via Quartus II Software.
I am trying to read Altera EMP7032SLC44-10 IC software. I need to get the software from inside the IC.
I am connection to Al...
YuanLi_S_Intel
5 years agoAs mentioned previously, can you try with the JTAG Chain Debugging? It should show you the error message and root cause.
I suspected that the connection to the pin using the wire is the issue. The JTAG Chain Debugging will tell you the exact issue on connection such as short / open pin.
Samet
5 years agoHello
First of all, I want to ask.
1) Is adapter or reader required for communication other than Usb Blaster for EPM7032SLC44-10?
2) I am giving external 5V but it gives no chain jtag error in Quartus program. No device detected error.
3) How do I make which adapter or connection to activate EPM7032SLC44-10 communication ends? How to make connection details for IC or communication information of IC?
