Samet
5 years agoAltera Usb Blaster
Hello
I cannot communicate with USB Blaster via Quartus II Software.
I am trying to read Altera EMP7032SLC44-10 IC software. I need to get the software from inside the IC.
I am connection to Al...
YuanLi_S_Intel
5 years agoSorry it is not possible. We support via forum platform only.
I think your USB Blaster is installed successfully as you are able to detect USB Blaster in Quartus Programmer as per the photo attached. I think the problem is on the hardwired connection between USB Blaster & FPGA Device.
Can you try with the JTAG Chain Debugging? It should show you the error message and root cause.
- Samet5 years ago
I think I made the IC connection correctly. I connected the TMS, TCK, TDO and TDI connections from the blaster. I made the voltage connection on the blaster. but there is a situation that makes me think. I saw it while researching on the forums. Can the JTAG outputs be disabled when first programming this IC? Or can the IC be encrypted? Is there a status of being protected against reading?- Samet5 years ago
jtag connection error persists. JTAG connectors are correct for IC connection but gives jtag connection error on quartus. Could you please help me in more detail? I have to make this IC.
