Samet
5 years agoAltera Usb Blaster
Hello
I cannot communicate with USB Blaster via Quartus II Software.
I am trying to read Altera EMP7032SLC44-10 IC software. I need to get the software from inside the IC.
I am connection to Al...
YuanLi_S_Intel
5 years agoHi Samet,
Certificates expiry affects Blaster Driver installation. If you have already installed the driver, it should n't be the problem.
It would be better to connect to a 10 header pin.
Take a look at the USB Blaster connection, you need 10 pin for that.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr.pdf (Page 4)
Bruce
Samet
5 years agoI can not find a driver with a new certificate. It does not accept usbblasterI or usbblasterII certified drivers in the quartus directory. does not load. I think blaster cannot read my IC because there is no device library in quartus. If I give you an email address or whatsapp number, can you make the necessary installation to my computer by connecting remotely?
