8 years agoAltera Serial Flash Controller Regular I/O
I am currently using a Cyclone 10 LP device with an EPCS16 program memory in Quartus Prime 17.1 and Platform Designer. Is it possible to use the dedicated AS Pins as regular I/O together with the ...
8 years agoHi,
cyclone 10 lp does not support legacy epcs/epcqx1 flash controller ip. the respective documents will be updated. Consider either using ASMI Parallel IP or ASMI Parallel II IP which has similar feature: https://www.altera.com/en_us/pdfs/literature/ug/ug_altasmi_parallel.pdf https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug-asmi2.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
