8 years agoAltera Serial Flash Controller Regular I/O
I am currently using a Cyclone 10 LP device with an EPCS16 program memory in Quartus Prime 17.1 and Platform Designer. Is it possible to use the dedicated AS Pins as regular I/O together with the ...
8 years agoHello,
I wanted to use the Legacy EPCS/EPCQx1 Flash Controller, but I get the error message "Component epcs_flash_controller_0 does not support selected device family Cyclone 10 LP", see the attached screenshot. That is the reason why I tried the Serial Flash Controller IP, which only uses the dedicated pins. Is there another IP that provides the same functionality as the Legacy EPCS/EPCQx1 Flash Controller, but is supported by the Cyclone 10 LP? Can you reproduce this behaviour on Quartus Prime 17.1.1.593? Best regards Christopher
