8 years agoAltera Serial Flash Controller Regular I/O
I am currently using a Cyclone 10 LP device with an EPCS16 program memory in Quartus Prime 17.1 and Platform Designer. Is it possible to use the dedicated AS Pins as regular I/O together with the ...
8 years agoHi,
--- Quote Start --- Hello, thank you for your answer. As i mentioned in my post, I cannot use the EPCS Flash Controller IP in the Platform Designer for Cyclone 10 LP devices. The IP is marked as Legacy and i get the error message "Component xyz does not support selected device family Cyclone 10 LP". Even though the User Guide, as you mentioned, explicitly lists the Cyclone 10 LP device for this IP, I get this error message. I wanted to use the "Altera Serial Flash Controller" instead, but this IP does not provide the pins on the topmodule. Is there a IP that I am missing? Can you reproduce this behaviour on Quartus Prime 17.1.1.593? Best regards, Christopher --- Quote End --- I think you are using a serial flash controller IP. You should use legacy EPCS/EPCQX1 flash controller IP. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) https://alteraforum.com/forum/attachment.php?attachmentid=14935&stc=1
