10 years agoaltera_sc_fifo problem - invalid first transfer
Hello everyone! I am developing design, which includes Altera's Single Clock FIFO implementation. Unfortunately it doesn't seem to work properly. In my earlier projects valid transfers to...
10 years agoThey probably worked because the value changed much before the clock. You just got unlucky that you aligned all of your control signals just before clock edges.
Much safer to only use# for the clock, then everything else changes relative to the clock.
