15 years ago
altera_reserved_tck timing violation
Hi all,
I am running niosII UDPoffload reference design from (http://www.alterawiki.com/wiki/nios_ii_udp_offload_example). Everything goes on well until I met with removal timing violation on altera_reserved_tck of -2.243ns.
The tck constraints look like following:# ---------------------------------------------------------------------------# JTAG interface input and output delays# ---------------------------------------------------------------------------
set_input_delay \
-clock [ get_clocks altera_reserved_tck ] \
10.0 \
[ get_ports { \
altera_reserved_tms \
altera_reserved_tdi \
set_output_delay \
10.0 \
[ get_ports { altera_reserved_tdo } ]
I noticed the following two lines are commented out:# create_clock -period 10MHz {altera_reserved_tck}# set_clock_groups -asynchronous -group {altera_reserved_tck}
What's the root cause of these removal timing violations? Should I uncomment the above two lines (I assume altera tools will automatically create this altera_reserved_tck instead of user manually create in user's sdc, am I right)?
FYI, the timing report is following:
Critical Warning: Timing requirements not met
Info: Worst-case removal slack is -2.243
Info: Slack End Point TNS Clock
Info: ========= ============= =====================
Info: -2.243 -2.243 altera_reserved_tck
Info: 0.973 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[2]
Info: 1.004 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[0]
Info: 1.007 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[1]
Info: 1.017 0.000 clkin_125
Info: 1.024 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|scan_clk|q_clock
Info: 1.393 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[4]
Info: 2.094 0.000 test_sys_sopc_inst|the_enet_pll|the_pll|altpll_component|auto_generated|pll1|clk[1]
Info: 2.521 0.000 test_sys_sopc_inst|the_ddr_ram|ddr_ram_controller_phy_inst|ddr_ram_phy_inst|ddr_ram_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[3]
Info: The Metastability Analysis global option is set to OFF.
Warning: The launch and latch times for the relationship between source clock: altera_reserved_tck and destination clock: test_sys_sopc_inst|the_enet_pll|the_pll|altpll_component|auto_generated|pll1|clk[1] are outside of the legal time range. The relationship difference is correct, however the launch time is set to 0.
1 Reply
    Yes, you should uncomment those two lines in order to avoid the fake timing violation warning.
    I had the same problem. If you search the forum, you'll find a few posts which refer to this anomaly.
