11 years agoYes. Older versions of the web edition support 32 bit. The last version to support 32 bit is 13.1. You may not be able to compile some designed for cyclone V though, as the dev says that Cyclone V is "not recommended" on 32 bit OS. The smaller devices are recommended to have 6GB ram, with the larger ones needed 8GB.
