8 years agoAltera Quartus: Compilation Problem
Hi, I am using Altera Quartus Web Edition 15. No issues in Synthesis process [done 100%] then after starting Compilation it`s processing is keep on going for endless. No Compilation Error Me...
8 years agoI am getting the foll0wing critical warning messages. Whether that critical warning messages make compilation process to fail.
Critical Warning (12887): Too many 2.5-V SE IO in bank 7A with LVDS RX pin DIFF_CLK_IN[0]. Reduce the number of 2.5-V I/Os used and re-run the analysis again. Please refer to the guideline from the Knowledge Base solution ID: rd10102013_979 and ensure the total % of SSN for the following SE I/O pins does not exceed 100%. Critical Warning (12887): Too many 2.5-V SE IO in bank 4A with LVDS RX pin DIFF_CLK_IN[1]. Reduce the number of 2.5-V I/Os used and re-run the analysis again. Please refer to the guideline from the Knowledge Base solution ID: rd10102013_979 and ensure the total % of SSN for the following SE I/O pins does not exceed 100%. Critical Warning (12887): Too many 2.5-V SE IO in bank 4A with LVDS RX pin DIFF_CLK_IN[2]. Reduce the number of 2.5-V I/Os used and re-run the analysis again. Please refer to the guideline from the Knowledge Base solution ID: rd10102013_979 and ensure the total % of SSN for the following SE I/O pins does not exceed 100%.
