11 years ago
Altera Qsys Generated Pci Express Wrapping
I have problem with pci express avalon busses. Altera's ip core has may input output on generated module. I didnt figure out how to drive all those io.
My board has following pci express signals,
PCIE_PERST_N PCIE_REFCLK_P PCIE_RX_P PCIE_TX_P PCIE_WAKE_N
And i only need tx_en, tx_data, tx_busy, rx_en,rx_data.
How can i wrap qsys generated module?
1 Reply
    You will need those signals to drive the PCIe HIP (module). For example the refclk is the PCIe reference clock that the transceivers need, the perstn is a reset input that is also derived from an input pin. There is quite a reasonable Altera pdf explaining the PCIe Avalon MM core, so it's best to have a read first, or you will not understand how to drive the core.
