11 years agoYou will need those signals to drive the PCIe HIP (module). For example the refclk is the PCIe reference clock that the transceivers need, the perstn is a reset input that is also derived from an input pin. There is quite a reasonable Altera pdf explaining the PCIe Avalon MM core, so it's best to have a read first, or you will not understand how to drive the core.
