11 years agoAltera PCIe Hard IP avmm for cyclone V quartus synthesis warnings
Good Afternoon, I'm using the PCIe Hard IP avmm Gen2 x1 in my design. There are a clock generator, a reset generator, the Hard IP configured as endpoint and an on-chip memory. I created the syn...
11 years agoThank you for your answer nic_@.
These are the warnings. Synthesis: Warning (10034) Output port "testout" at altpcie_cv_hip_avmm_hwtcl.v(291) has no driver Warning (10034) Output port "txsynchd0" at altpcie_cv_hip_avmm_hwtcl.v(485) has no driver Warning (10034) Output port "currentcoeff0" at altpcie_cv_hip_avmm_hwtcl.v(493) has no driver Warning (10034) Output port "currentrxpreset0" at altpcie_cv_hip_avmm_hwtcl.v(501) has no driver Warning (10034) Output port "txdatavalid0" at altpcie_cv_hip_avmm_hwtcl.v(428) has no driver Warning (10034) Output port "txswing0" at altpcie_cv_hip_avmm_hwtcl.v(468) has no driver Warning (10034) Output port "txblkst0" at altpcie_cv_hip_avmm_hwtcl.v(477) has no driver Warning (10764) Verilog HDL warning at altpcie_av_hip_ast_hwtcl.v(1264) converting signed shift amount to unsigned Warning (10858) Verilog HDL warning at altpcie_av_hip_128bit_atom.v(1480): object rst_ctrl_rxanalogreset used but never assigned Warning (12011) Net is missing source, defaulting to GND Warning (12020) The extra bits will be ignored Warning (12010) The extra bits will be driven by GND Warning (12030) The extra bits will be left dangling without any fan-out logic Fit: Critical Warning (184043) Fitter was unable to find Transceiver Reconfiguration Controllers associated with the following 2 XCVR PHY IP component blocks
