10 years agoAltera OpenCL SDK with Visual Studio 2015
Hi, Is there anyone tried to setup the development environment with VS2015 and successfully build the Host program? The VS2010 is used in the Altera get started guide for the env setup. I ...
10 years agoyou probably run into some incompatibly issue? to ensure what you trying to suspect is correct, maybe do a quick one by down grading to VS2010 and redo then.
