AKost
8 years agoAltera-Modelsim can not start on Ubuntu 18.04
Hi, I installed the Modelsim Altera edition and now i can not start it. I downloaded the .run file, made it executable using chmod +x command and than ran it. It installed without problems into ~int...
mfro
8 years agoThere are at least two issues with modelsim and current Ubuntu/Debian 64 bit installations:
- you need to have installed all required 32 bit libraries
- modelsim crashes with current libXft libraries. You need to install an older version to make it run
Since I usually can't remember what I have done last time, I bookmarked https://gist.github.com/PrieureDeSion/e2c0945cc78006b00d4206846bdb7657 that has a good recipe on what to do to make modelsim run
