AKost
8 years agoAltera-Modelsim can not start on Ubuntu 18.04
Hi, I installed the Modelsim Altera edition and now i can not start it. I downloaded the .run file, made it executable using chmod +x command and than ran it. It installed without problems into ~int...
ELave
8 years agoYou're unlikely to get an answer from Intel, so you're probably on your own. 'vlm' may point to a licensing failure. What happens if you run vcom, vlog, vlib, etc? Do they work? If so, that would also point to a licensing failure.
Installation on RH/Centos completes easily and everything just runs. However, there are issues if you are on a 64-bit system (like everybody else). Intel appears to be unable to offer any advice on that.
