16 years agoAltera Installer on Fedora 12 (and other Linux distros)
running the Altera Installer on Fedora 12, you might see and error with libXi.so as we've seen in the past running quartus: $ ./altera_installer.external.mod.sh
Creating directory bin
Verifyi...
16 years agoIf you run the .sh file again then it will uncompress everything again and restore the offending .so. So everything gets uncompressed in the 10.0_quartus_linux dir. In that dir is a file called setup. I ran that after deleting the so.
I am on F13 and had to fix the paths like you mention and then change the SElinux/conf file to allow SE Linux to be permissible so the quartus tools can launch. -Rolando
