Altera Corporation APU USB Driver Not Signed
- 4 years ago
Hi reschrei,
I am glad that the problem is solved on your side. FYI, APU USB Driver is an old driver and won't be compatible with current windows any longer. Only the USB Blaster Driver instead is needed for the latest windows (10 and above).
Looking forward to hearing your update.
Fakhrul
Hi reschrei,
When you're trying to create a new project, have you tried to choose the project folder where you have read and write permission?
Fakhrul
- reschrei4 years ago
Hi Fakhrul,
I tried again and changed the default project directory to a new location that has Full Control by all users. The Quartus seemed to create a new project file without issue this time.
I'm going to check back with the customer I'm working with to see if they can get their projects working. I'll come back with an update to see if this solves things.
They seemed adamant that the driver needed to be installed, but I will confirm as I haven't been able to get this far previously.
Thank you!
reschrei
