10 years agoALTDDIO_OUT error 15874
Hi, I don`t know if this is the right forum for creating this thread. I have a problem when I use the ALTDDIO_OUT IP component in Quartus II, for a Cyclone V device. I want to use the same outp...
10 years ago --- Quote Start --- the ddr output is meant for external output only (not inside fpga). you can mux your high/low inputs into ddr instead --- Quote End --- The problem is that I have to use the same output pin for two signals. I mean, I want to mux the output, not the input. If I mux high/low I will have the same problem in the output pin. Or maybe I have not understood your proposal.
