alt_signaltap_run shuts down Matlab(2016a)?
- 6 years ago
Dear BazingaWei,
What Quartus version do you use? Usually, Matlab is very sensitive when there is a different Q version:e.g. you should use Quartus 16
As per my discussion with SW team, you may refer to the following KDB to see if it is helpful. Please let me know if there is any concern. Thank you.
Hi, CheePin_C_Intel,
sorry for late, i'm kind of busy with other stuff now. Thanks for your time and you discussion, but i don't know the KDB you refer to, also have no ideal where to find the 'following KDB' you suggested. If you don't mind, please make it clear, thanks.
Best Regard
- Melissa_M6 years ago
Hi, did you ever resolve this issue? I am having a similar problem.
- BazingaWei6 years ago
This problem happens when the DSP-Builder in your Quartus doesn't match to your Matlab version. You may refer to the following file.
- Melissa_M5 years ago
Hi, thanks for the response. I'm a bit confused. If you don't mind elaborating more:
Are you saying I need a DSP-builder blockset from mathworks in order to just be able to use the alt_signaltap_run ? All I want is to get data into matlab from signal tap. This use to be easy (back when I used Quartus II 13.1 and matlab R2010)
I have the Quartus Prime Standard edition - according to the document you sent, it doesn't even support the DSP-builder? So I can't get data into matlab using the alt_signaltap_run without upgrading to pro edition?
