BazingaWei
6 years agoalt_signaltap_run shuts down Matlab(2016a)?
When i ran 'alt_signal_run' on Matlab 2016a, Matlab was forced to be shut down. I have add the installation path of Quartus bin in the system env. variables.
is there anyone who has experience to ...
- 6 years ago
Dear BazingaWei,
What Quartus version do you use? Usually, Matlab is very sensitive when there is a different Q version:e.g. you should use Quartus 16
dsmirnov
6 years agoDear BazingaWei,
- BazingaWei6 years ago
Hi, dsmirnov,
sorry for late reply and thanks for the suggestion. I'm using Quartus 14.1, i'll try your suggestion.
Best Regards
i tried with Quartus 16.1, it can work with Matlab 2016a, although the problem still rises sometimes, but it works at least. Thanks a lot.
