alt_signaltap_run shuts down Matlab(2016a)?
- 6 years ago
Dear BazingaWei,
What Quartus version do you use? Usually, Matlab is very sensitive when there is a different Q version:e.g. you should use Quartus 16
As per my discussion with SW team, you may refer to the following KDB to see if it is helpful. Please let me know if there is any concern. Thank you.
- BazingaWei6 years ago
Hi, CheePin_C_Intel,
sorry for late, i'm kind of busy with other stuff now. Thanks for your time and you discussion, but i don't know the KDB you refer to, also have no ideal where to find the 'following KDB' you suggested. If you don't mind, please make it clear, thanks.
Best Regard
- Melissa_M6 years ago
Hi, did you ever resolve this issue? I am having a similar problem.
This problem happens when the DSP-Builder in your Quartus doesn't match to your Matlab version. You may refer to the following file.
