Lorne_K_Intel
5 years agoalt_ehip3_0 example design fails load alt_ehipc3_0 toolkit
Generate example design with
active channels : 10/29GE channels
single channel
RSFEC enabled : first_lane3,
ANLR enabled
example design : design completes build , fails to load
Oct 15, ...
Deshi_Intel
5 years agoHi,
Can you share more detail so that I can debug and duplicate your issue in house
- May I know which Quartus version that you used ?
- Which FPGA product that you used ? Can you share with me the Ethernet IP QSYS file or IP file ?
- Which Intel dev kit board that you used ? Did you configured the dev kit board on board switch setting correctly ?
- Can you elaborate further on the procedure steps on how you run the software tool ? Which software tool to be precise here ?
dlim
