14 years agoAIIGX configuration scheme
I am using AIIGX fpga along with serial configuration device from Micron. We are using AS configuration mode, in relation to this I have following queries, any help on this would be appreciated. 1. Is AIIGX fpga support non-Altera serial configuration devices? 2. If it is possible then how can I generate a bit stream target to non-EPCS part (in my case Micron device, data sheet attached)? 3. Is there any particular care needed on PCB level to handle above scenario? Thanks, R Shaik.
