10 years agoAfter change the hdl code,should I disable signaltap before recompile?
I have read article about using signaltap ii when design does not run correctly. It said I should set the top partition to Post-Fit. Then SignalTap is put into its own partition and therefore won't a...
10 years agoAdding signaltap should not affect the design, other than possibly causing timing failures because it now struggles to fit from a large design. But it should not affect the design from an HDL point of view.
What problems are you having?
