10 years agoAddressing unmapped memory space results in unpredictable behavior
Hi folks, Searching for a stubborn error, I came across the following behavior: When an avalon memory mapped master (for example NIOS) writes to an address, that is not mapped to any qsys ...
10 years agoThanks for the ideas.
I'm using Quartus II 13.1 (latest version to support our Cyclone III FPGA). --- Quote Start --- Have you tested and proven that something is getting written somewhere that you don't expect? --- Quote End --- The actual error I'm targeting occurs only once per month or so, so it's very hard to find and I couldn't prove that it's actually caused by a write to unmapped memory. But what I proved is, that when NIOS writes to unmapped memory deliberately, the write gets assigned to another custom memory mapped component which as a result causes the error I'm looking for. --- Quote Start --- I created several instances and set the addressing so that they collectively covered most of the 32 bit address space that wasn't used by other components. --- Quote End --- I also thought about filling the unused memory space, just to cover all the addresses, but I haven't tried it yet. I have two masters in my system that can write to the component in question (NIOS and an external DSP). It would help a lot, if I knew which (if at all) is causing the problem...
