--- Quote Start ---
Look again at the link you posted, the function is over-loaded for both SIGNED and UNSIGNED.
-- Id: R.1
function RESIZE (ARG: SIGNED; NEW_SIZE: NATURAL) return SIGNED;
-- Result subtype: SIGNED(NEW_SIZE-1 downto 0)
-- Result: Resizes the SIGNED vector ARG to the specified size.
-- To create a larger vector, the new bit positions
-- are filled with the sign bit (ARG'LEFT). When truncating,
-- the sign bit is retained along with the rightmost part.
-- Id: R.2
function RESIZE (ARG: UNSIGNED; NEW_SIZE: NATURAL) return UNSIGNED;
-- Result subtype: UNSIGNED(NEW_SIZE-1 downto 0)
-- are filled with '0'. When truncating, the leftmost bits
-- are dropped.
as I comment above, the MSBs of an unsigned number are '0' extended.
I'm not sure what you mean by this. If you need 32-bits to represent a modulo-32 bit operation, then it does not matter if that 32-bit number uses signed or unsigned representation. In either case, you still need 32-bits. I'm not sure why you think signed would need 1-bit less.
As for your RTL view ... personally I'd recommend starting with Modelsim and making sure your testbench produces the correct results, and then worry about synthesis.
Cheers,
Dave
--- Quote End ---
To avoid confusion I would declare the presumed unsigned value as signed "0"&value.
Though we can use resize for either signed or unsigned but I am not sure what happens if we resize an unsigned value cast as signed inside this function. I would rather just avoid it.
