[SOLVED] [?]
Since the Integer type doesnt work at 32 bit (it uses the bit 31 as carry, as the RTL shows) I worked 2 strategies to solve it:
For the ROT counter, I shifted all the logic one bit to the right, so i actually use 31 bits
ROT <= buffRot(30 downto 15);
subDecRot <= STD_LOGIC_VECTOR(TO_UNSIGNED(TO_INTEGER(UNSIGNED(buffRot)) - TO_INTEGER(UNSIGNED(RELATION)),32));
subIncRot <= STD_LOGIC_VECTOR(TO_UNSIGNED(TO_INTEGER(UNSIGNED(buffRot)) + TO_INTEGER(UNSIGNED(RELATION)),32));
For the 46 bits variables, I have implemented the sum as another VHDL file (even knowing it could be done with an function)
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity ADDER_46 is Port (
A : IN STD_LOGIC_VECTOR (45 downto 0);
B : IN STD_LOGIC_VECTOR (45 downto 0);
C : OUT STD_LOGIC_VECTOR (45 downto 0);
COUT : OUT STD_LOGIC;
CIN : IN STD_LOGIC
end ADDER_46;
architecture Behavioral of ADDER_46 is
signal Carry: STD_LOGIC_VECTOR (46 downto 0);
begin
Carry(0) <= CIN;
COUT <= Carry(46);
Carry(46 downto 1) <= (A and B)or(Carry(45 downto 0) and (A or B));
C <= (A xor B)xor Carry(45 downto 0);
end Behavioral;
Still, I think the designers of Quartus should give a look at the image I have posted in the first post.
