Adding of Block system file to NIOS Processor
- 4 years ago
I was confused because .bsf is a block symbol file, not block system file.
In any case, a Nios processor must be created in a Platform Designer system. When you generate the system, you can choose the option to create a .bsf file for the system, which you can then include in a .bdf schematic file and connect to your code.
Or you could turn your code into a Platform Designer custom component and connect it to Nios in Platform Designer, but that requires knowledge of using Component Editor in Platform Designer.
