14 years agoyou shouldn't have to manually run jtagserver.exe, so i'm not sure how to set it up because its typically done during installation. do you have admin rights on the PC?
if the USB Blaster driver is installed correctly, it will appear in the pull down in Hardware Setup. you don't need any server information so my guess is the USB Blaster driver didn't get installed properly. to reinstall it, go to Start > right click on My Computer > Properties > Device Manager >Universal Serial Bus controllers > look for the Altera USB Blaster > right click Uninstall then unplug the USB Blaster, wait a second, then plug it back in. point the driver installer to C:\altera\11.0sp1\qprogrammer\drivers\usb-blaster or similar. then try the programmer again
