12 years ago
Adding "Altera_UP_SD_Card_Avalin_Interface"
Hy guys,
I am working with SD card in my project. I did the searching and find http://www.alteraforum.com/forum/showthread.php?t=34495. My objection is NEARLY similar as the post. Which is adding/editing .txt files inside the SD card.
I downloaded the University Program IP cores from : http://www.altera.com/education/univ/software/upds/unv-upds.html (FYI, I am using Quartus 10.0).
Then I added only the "altera_up_sd_card_avalon_interface.vhd" from the hdl folder since if I added all of the .vhd files, I will get the family device error (adding_ip_error attached picture*). Here is my first question, do I need to add all of the .vhd files or only altera_up_sd_card_avalon_interface.vhd is enough?
When I added "altera_up_sd_card_avalon_interface.vhd" only, the compiler give me an error. (compiling_error attached picture*). Here is my second question, is there anyway to fixed this problem?
I dont know if it's allowed for me to attached the entire altera_up_sd_card_avalon_interface folder to this forum.(sd_cores_files attached pictures*)
Thank you in advance!
Yuyex ;)
