16 years agoThanks, I can follow that!
Looking at the clock map for the Cyclone 3 (handbook vol 1), it shows PLL1 and PLL3 alongside clock pins 0 to 3 (left hand side). However PLL2 is on the opposite side of the chip (along clocks 4 to 7) right hand side, with no "decent" path from the LHS, so no wonder it wouldn't play ball. As a test, I created a third PLL, which worked (compensated) OK with clock pin 11 (top side), and also pin 1 (left side). So now I got a much better feeling of what is going on.. thanks both!
