15 years ago --- Quote Start --- Thanx Sha, thats exactly what i did, but i'll just go through it again and check if the pins are correctly assigned and if i still experience any problem, i will let you know. Thanx bro Regards --- Quote End --- Hi, how does the design inside the FPGA lookslike ? Is it only a feedthrough of the ADC data ? If not maybe you have a problem inside of your design. To check of your ADC data goes inside the FPGA corretly could be observed with signaltap. Kind regards GPK
