10 years ago
ADC 0804 in FPGA DE2-70
Hello there team Altera,
I have a project regarding the implementation of ADC 0804 in FPGA DE2-70, I have very bad super vision and am really weak in coding as well and all am looking for is the coding for is the Quartus II simulation with the ModelSim test bench.
I have tried this coding but am not sure how to make it fit plus its missing the ModelSim test bench.
taken from the attached paper.
else
begin
data_in[13] = data_in[11] ; // shift register to accumulate
// data bits
data_in[11] = data_in[9] ;
data_in[9] = data_in[7] ;
data_in[7] = data_in[5] ;
data_in[5] = data_in[3] ;
data_in[3] = data_in[1] ;
data_in[1] = data_sd0 ; // add new data bit into shift
// register
end
end
// Shift register to capture the serial data from data_sd0 port on negative edge
always @(negedge outclk or posedge rst)
begin
if (rst)
begin
data_in[12] = 1'b0 ;
data_in[10] = 1'b0 ;
data_in[8] = 1'b0 ;
data_in[6] = 1'b0 ;
data_in[4] = 1'b0 ;
data_in[2] = 1'b0 ;
data_in[0] = 1'b0 ;
end
else
begin
data_in[12] = data_in[10] ; // shift register to accumulate
// data bits
data_in[10] = data_in[8] ;
data_in[8] = data_in[6] ;
data_in[6] = data_in[4] ;
data_in[4] = data_in[2] ;
data_in[2] = data_in[0] ;
data_in[0] = data_sd0 ; // add new data bit into shift
// register
end
end
// data capture at frame signal
always @(posedge frame or posedge rst)
begin
if (rst)
begin
datareg0 = 14'b00000000000000 ;
wr_addr = 9'b000000000 ; // initialize the memory write address
// counter
wr_enable = 1'b1 ; // initialize the memory write enable
// signal
end
else
begin
datareg0 = data_in ; // add new word of data into data register
if (wr_enable)
wr_addr = wr_addr + 1 ; // increment the address counter
else
wr_addr = wr_addr ; // hold the address counter at this value
if (wr_addr[9])
wr_enable = 1'b0 ; // disable write enable when address MSB = 1 // to prevent overwriting data in memory
else
wr_enable = 1'b1 ;
end
end
endmodule
If you can help in any kind of way please let me know am hopeless and you're my only hope.
thank you.
