A couple of suggestions:
1) Look at the 2's compliment data and sign-magnitude data values. Is your conversion logic correct? 2) Create a Modelsim simulation and check your logic. Cheers, Dave - Altera_Forum
--- Quote Start --- When I want to capture a block of samples from an ADC, I'll typically write my own code to capture to a RAM block or multiple RAM blocks. The RAMs are configured as dual-ported, with one side connected to the ADC, and the other connected to an Avalon-MM system. I then read the captured samples from RAM using the JTAG interface, via the method described in this tutorial http://www.alterawiki.com/wiki/using...aster_tutorial --- Quote End --- In this tutorial, in "software version" section It is mentioned that:The tutorial was developed using Quartus II 11.1sp1 (full edition) under Windows XP Professional 32-bit. Quartus II 11.1sp1 (full edition)--> means "Subscription Edition" am I right? and that means it doesn't work with Web Edition (free) or it also works with web edition? - Altera_Forum
--- Quote Start --- In this tutorial, in "software version" section It is mentioned that:The tutorial was developed using Quartus II 11.1sp1 (full edition) under Windows XP Professional 32-bit. Quartus II 11.1sp1 (full edition)--> means "Subscription Edition" am I right? and that means it doesn't work with Web Edition (free) or it also works with web edition? --- Quote End --- Read the tutorial - Appendix A lists all the versions I tested the scripts under - including Web Editions. Cheers, Dave
