to my knowledge, PCI clamp diode is available for all Cyclone pins, the same with Cyclone II: It can be enabled in Assignment Editor or Pin Planner (after activating the PCI-IO column). But I never used it, mainly for the following restriction, that makes the option effectively useless in interfacing 5V signals to my opinion:
--- Quote Start ---
Because 5.0-V tolerance in Cyclone devices require the use of the PCI clamping diode, and the clamping diode is only available after configuration has finished, be careful not to connect 5.0-V signals to the device. (From Cyclone devive handbook)
--- Quote End ---
I suggest to use resistive dividers or 74LVC buffers instead.
Frank
