11 years agoAccessing SRAM from NIOS and Verilog Module
Hi, I have implemented the Web Server example on the DE2-115 and modified it a bit to send data over ethernet to the DE2-115 board and store it in the SRAM. This data is around 1Mbit . Next I ...
11 years agoHere are couple of Avalon templates that you can make use of them
For master, https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-avalon-mm.html For slave, https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-avalon-memory-slave.html
